03 Accord strange noise from sepentine belt area
Old Mar 27, 2012 | 09:08 PM
ljber's Avatar
Default 03 Accord strange noise from sepentine belt area
Hi my 2003 Accord lx 4cylinder has now has a strange noise coming from sepentine belt area. I replaced the tensioner pulley but noise still there. I removed the serpentine belt again and noticed that the larger lower idler pulley wobbles (no sure if that's what it"s called). Is that normal. I can't see a screw to remove and replaced if it has a bad bearing. Is it safe to drive?
Thanks
Old Mar 27, 2012 | 10:51 PM
I don't think there is an idler pulley on the serpentine belt. Could you post a picture showing the pulley?
Old Mar 28, 2012 | 08:01 AM
ljber's Avatar
PAhonda thanks for the reply, attached is the picture. Red arrow indicates the pulley that is loose or wobbles that I suspect the noise is coming from.
Attached Thumbnails 03 Accord strange noise from sepentine belt area-2003-accord-serpentine-belt.jpg
Old Mar 28, 2012 | 12:33 PM
That is your water pump. That is important. Pay close attention to your temperature gauge in the car, because you do not want to overheat the car until this is fixed.
The water pump is #6 in the diagram.
Old Mar 29, 2012 | 07:39 AM
ljber's Avatar
What I'm I looking at to get this replaced. Is that had to replace?
Thanks
Old Mar 29, 2012 | 10:32 AM
You should be able to drain the coolant, remove the belt, then unbolt the water pump. Installation is the reverse.
I am not sure how much room you have to access the bolts for the water pump. I never did this job on a K-series engine.
Old Mar 30, 2012 | 05:59 PM
PA nailed it, the manual says the tensioner has to come off.
Attached Thumbnails 03 Accord strange noise from sepentine belt area-7th-gen-4-cyl-wp.jpg
Old Apr 9, 2012 | 09:56 AM
ljber's Avatar
Thanks, it was the water pump. Nice and quiet now.
briggsrepair
Sep 13, 2013 10:17 AM
95Coupe_360
Jul 19, 2013 12:31 AM
barryfaetheus
Apr 29, 2011 05:43 PM
elgwedoloco
West
11
Dec 13, 2010 03:01 PM
kayemmmm
Sep 12, 2007 05:11 PM
