'03 Coupe Rear Strut Flange Bolt Size
Old Sep 23, 2015 | 12:21 AM
Grand Rapids's Avatar
Default '03 Coupe Rear Strut Flange Bolt Size
Hey guys,
I replaced my LR strut with no issue, but the lone bottom flange bolt on my RR strut needs to be cut out as it is impossible to remove otherwise.
I have scoured via Google and this site trying to find the correct size of this bolt and I have not found it.
Can anyone tell me the size of this bolt, where I can find a replacement and any other helpful info?
Thanks. '03 Accord coupe.
Old Sep 23, 2015 | 10:52 AM
Do you mean one of the two nuts that mount the upper strut end to frame or the strut/lower arm bolted pin connection? There is no flange at lower end.
The lower strut/lower arm bolt is a 12mm (bolt diameter) x 84mm length. It is a high strength bolt and should be purchased from Honda. Hardware store bolts are not high strength.
Old Sep 23, 2015 | 03:49 PM
I meant the one lower bolt. What type of metal is this? Also, I can't find that bolt on any Honda parts website. .
Old Sep 23, 2015 | 06:12 PM
Bolt is high strength steel. See attached parts diagram. It's part 17, available from any Honda parts website or parts house.
Old Sep 23, 2015 | 10:50 PM
Discovered below. From Michigan, thank you for your help, Texas Honda.
REAR SHOCK ABSORBER Honda OEM Parts -- 2004 HONDA ACCORD for 2DR EX - Automatic All&vinnoT=&trim=&trans=&view=normal
drifterz73
Sep 29, 2013 02:20 AM
UMDCornholio
May 11, 2010 04:55 PM
Rodders
Mar 21, 2009 04:36 PM
Castor Troy
May 18, 2007 05:38 PM
stratijikal
Jul 29, 2006 03:31 AM
