04 Accord coupe door locks
Old Jun 22, 2006 | 05:24 PM
hurkes
Default 04 Accord coupe door locks
The driver side lock can only be locked manually. Neither the keyless or nor the lock/unlock button will work. Any ideas on whats going on?
Old Jun 22, 2006 | 08:09 PM
Chiovnidca's Avatar
Default RE: 04 Accord coupe door locks
ORIGINAL: hurkes
Does the lock actuator get power and ground?
Old Jun 23, 2006 | 01:19 PM
hurkes
I actually have not dug into it yet, I was seeing if there were any "usual supspects" for this particular problem. But its funny that you brought up power and ground, because the keyless worked ONCE yesterday. I am not a certified tech but have turned wrenches my whole life is it something a pro should do or is it simple enough to proceed.
Old Jun 23, 2006 | 01:51 PM
sir_nasty's Avatar
it's easy.... the hardest part is figuring out exactly how the door panel is removed... from there it's just a matter of testing with a volt meter.... I'm sure if you've been turning wrenchs for a while that you can figure it out
trolddk
Jul 3, 2013 06:08 PM
lisam
Apr 16, 2009 06:55 AM
edeloca
Mar 4, 2009 03:37 PM
abhanu
Mar 31, 2008 11:02 AM
03 Coupe
Feb 22, 2007 06:32 PM
