04 accord v6 coupe tranny issue
Old Dec 31, 2016 | 09:33 PM
djpoint5ive's Avatar
Default 04 accord v6 coupe tranny issue
Hey guys! Just bought a used 2004 honda accord v6 coupe that seems to have a problem with shifting. After a certain amount of time driving the car, it suddenly shifts into neutral and looses connection until i release the gas. About a day after, i got a trouble code that read p0741and it said poor performance from torque converter clutch solenoid. I checked the fluid level and saw that it was low and a little aged so i did a drain and refill with Honda Genuine ATF and replaced a leaking seal near the shifter linkage. Now the fluid is topped off and there are no leaks but it still seems to do the same thing every once in a while. I also notice that its a little slow to go into reverse. Is my tranny severely damaged from the fluid leak and im doomed? Or should i try removing that particular solenoid and cleaning it? I love this honda and would like to save it!
Old Jan 2, 2017 | 06:08 PM
You can test the solenoid w/ 12V wired from battery to check that solenoid clicks when voltage applied. If no sound, replace solenoid. After that it gets more difficult to follow the diagnostic (attached).
File Type: pdf
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
bkwill
Apr 18, 2007 09:26 PM
Cajun
Aug 30, 2006 11:24 PM
