1989 Honda Accord IACV location
Old Feb 16, 2014 | 09:54 PM
terro45's Avatar
Default 1989 Honda Accord IACV location
Hello all. I am attempting to clean the IACV on my 1989 carbureted Honda Accord, but there is one small problem that I am hoping you all can help me with... I can not located the thing! Any info. on the location of it would be greatly appreciated. Thanks.
Old Feb 17, 2014 | 08:34 AM
A carbureted car does not have an IACV. Idle is control w/ steps on the throttle stop cam and linkage to choke usually.
A shop manual will help.
Old Feb 17, 2014 | 01:17 PM
terro45's Avatar
Thanks for the quick response. No wonder why I couldn't find the dang valve! lol.
Old Feb 17, 2014 | 04:31 PM
Doesn't the carburetor have a rudimentary idle-control system?
Parts drawing shows a "frequency solenoid valve" part #35 & "air control" valve #14. Together they are the ancestors of the IACV that we know today.
If you're chasing an idle problem, I guess you could clean them. I don't know anything about any adjustment or setup that might be needed. But don't forget to look for vacuum leaks anywhere in that rats nest of tubing.
Old Feb 21, 2014 | 05:34 PM
What issue are you having with it? I "fairly" good with these 3rd gen carb's.
Old Feb 22, 2014 | 06:30 PM
terro45's Avatar
The issue I'm having with it is that it completely stalls out when coming to stops or slowing down to take turns. It idles fine when in park but dies out when shifting into drive or reverse if you don't feather the gas pedal. Thanks for the help.
Old Feb 23, 2014 | 09:04 AM
Kind of sounds like a vac leak, the load of placing it in gear....or "letting off" the gas quickly.
Check for vac leaks, as Jim stated there is a "rats nest" of tubing. Also check around that base plate of the carb. While you are there, might as well give the throat a good cleaning as well.
While the air cleaner base is off, check the float level as well - there is a "sight glass" on the side of the carb. Stand at the drivers tire and look at the carb and you will see it.
Old Feb 24, 2014 | 09:38 AM
I've seen auto-trans carburators where there's a solenoid that pushes on the throttle bellcrank when you shift the transmission into gear. That opens the throttle a bit to keep it from stalling. Does this carburetor have that kind of mechanism?
Having said that, all my carburetor cars have been manual transmission so I'm sorta guessing.
Old Feb 25, 2014 | 02:16 PM
terro45's Avatar
I recently had that solenoid checked and it worked fine, I did find a missing needle screw on the rear of the carb that is hopefully the cause of my issues. There is gas puddling in the carb when its idling. Thanks for the advice.
Old Feb 25, 2014 | 06:25 PM
If you cover the hole with your finger does it get any better? Either way if there is a "mixture" screw missing. Get that replaced and then see what you have.
The "puddling" in the carb at idle has me thinking of another issue but let's take one at at a time.....what did the float level look like?
kyoro
May 29, 2014 09:00 PM
chrisskingsley
Mar 19, 2014 06:05 PM
acesn8s
Nov 6, 2011 05:14 PM
njmodi
Jun 29, 2009 12:11 PM
