1990 Accord electrical issue
Old Jun 26, 2007 | 05:46 PM
namxas
Default 1990 Accord electrical issue
My 1990 Accord's cooling fan wants to run whenever it feels like it. The relay was clicking rapidly a couple months ago, but didn't have any problems other than that. Now my battery is going dead in a matter of a couple days (without driving it). I tried to leave the fuse for the fan out and see if that worked, but the battery still went dead. I also tried swapping the power window relay for the cooling fan relay, but it still did the same thing. Could a bad battery cause all this, or do I have a problem with a thermoswitch?
Thanks,
josh
Old Jun 26, 2007 | 05:54 PM
sir_nasty's Avatar
Default RE: 1990 Accord electrical issue
If you know that your car is going to be sitting for a few days I'd disconnect the battery cables and then test the battery after a couple of days and see if it's got a full charge still. I've seen weak batteries do some pretty funky things and since that's the cheapest/easiest thing to test I'd start their, if the battery is fine then we'll move on!
Old Jun 26, 2007 | 06:23 PM
namxas
Ok. Thanks, I'll start there. I'm going to drive it around tonight so the battery has a chance to take a good charge then disconnect it. I'll keep you posted on the outcome!
Thanks again,
josh
Brose_man
Nov 22, 2011 03:55 PM
caverspencer
Sep 6, 2010 01:20 PM
foxytsula
Jan 15, 2009 07:59 PM
mooretimothya
Dec 3, 2006 12:17 PM
