1991 accord clutch
Old Apr 14, 2009 | 10:42 AM
partsman1's Avatar
Talking 1991 accord clutch
Is there a way to adjust a clutch pedal on a 1991 accord ex?
Old Apr 14, 2009 | 11:14 AM
erikhans's Avatar
The clutch system is hydraulic. If you're having pedal issues you might want to check the fluid level... the clutch fluid reservoir is next to the brake fluid reservoir under the hood. You could also try bleeding the system... the bleeder bolt is located on the slave cylinder which is near the starter motor.
Old Apr 14, 2009 | 11:15 AM
Yeah, there's an adjustment on the piston rod behind the clutch pedal. But please go by the correct pedal height from a shop manual. The hydraulic cylinder needs to be positioned correctly in order to operate right. You shouldn't just raise & lower the pedal to suit you unless you want hydraulic problems in the future.
Old Mar 22, 2011 | 12:08 AM
ronnienow1's Avatar
i put a new master and slave cyinder on tonight on a 91 honda accord ex we blead the systim and still cant get the clutch to pressure,anyone know what my next move would be,
Old Mar 22, 2011 | 07:13 AM
Proper adjustment of the pushrod between the clutch pedal & the MC? I don't have a shop manual for 91 so I don't know the specifics.
You can try reverse bleeding. Use a pressure-bleeder (or some kind of syringe) to inject brake fluid into the bleeder, so it comes out into the MC reservoir.
Old Mar 22, 2011 | 06:06 PM
I also remember a post where a mis-adjusted push rod caused the new master to have a "stuck" piston...not saying that has happened but when you check the adjustment be sure the piston on the master isn't stuck in.
Old Mar 23, 2011 | 08:00 AM
Old Honda Dude's Avatar
Default ?
Who's problem first?
vetski179
Feb 24, 2015 04:26 PM
CB7-SE-1991
Jan 29, 2013 04:45 PM
JimBlake
May 18, 2009 09:38 PM
semocoachworks
Nov 28, 2008 08:24 PM
tamb
Jul 21, 2006 01:05 AM
