1991 accord lx clutch question
Old Nov 28, 2008 | 09:57 AM
semocoachworks
Default 1991 accord lx clutch question
hello all. i have a 91 accord that i put a clutch in yesterday. the problem is, where the slave cylinder hits thearm that pushes the throwout bearing, there is only about 1/4 inch of space for the slave cylinder to push the arm down to release the clutch before the arm is bottomed out. with the clutch installed and the car not running, clutch pedal not being pushed, how much should the slave cylinder rod be sticking out??? thank you in advance for any help!!!
1991 honda accord lx
16 valve pgm-fi 4 cyl engine
2-door
208000 miles
5-speed
Old Nov 28, 2008 | 08:24 PM
hondadude's Avatar
Default RE: 1991 accord lx clutch question
The post description is a little confusing.
The actual problem is the slave rod only moves 1/4' ???
Did you break loose the line when changing the clutch?
Did you bleed the clutch system?
Does the clutch not dis-engage when the engine is running?
vetski179
Feb 24, 2015 04:26 PM
CB7-SE-1991
Jan 29, 2013 04:45 PM
partsman1
Mar 23, 2011 08:00 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
