1991 Accord Ex No spark, New coil, New ignitor
Old Sep 26, 2015 | 05:02 PM
omar252's Avatar
Default 1991 Accord Ex No spark, New coil, New ignitor
I have a 1991 honda accord that will not start, Replaced main relay for fuel issue of not turning on pump. that is now fixed and have great fuel pressure. Now the issue came up was no spark I have replaced the Ignition coil with a brand new one and also ignitor with still no spark, have checked the Ecu fuse and also checked all grounds.... Could it be a faulty ECU?
Old Sep 26, 2015 | 07:37 PM
Check blk/yel wire at distributor for power w/ key in On position. It should have 12V. If 12V missing, ignition keyswitch is likely if you've checked ignition fuse.
Is Check Engine Light on? If yes, get the codes (see DiY forum).
dioalp
Jan 12, 2023 04:40 PM
phantomgrey92
Oct 9, 2013 04:45 PM
miraha
Jul 18, 2012 12:13 PM
brickballer
Nov 25, 2009 02:23 AM
thunder_x
Jul 13, 2006 03:00 AM
