1992 Accord Starting Problems
Old Aug 20, 2006 | 07:28 AM
masteve69
Default 1992 Accord Starting Problems
OK folks, I am newbee here but I have had my Accord since 1992. It is a LX 4dr Auto.
Over the past two years I have started to have problems starting the car in
afternoons during the summer. It only appears to happen when it is 85 degrees or
hotter outside. I have replaced the distributor, cap, rotor, plugs, wires, fuel filter,
fuel pump, and cleaned everything I can. It will fire once and then start to sputter.
Yesterday, I had my wife start it and I sat there for a few minutes with starter fluid into
the intake and kept it running. Then when you hit the gas it bogs down.. Any clue
would be appreciated. The car only has 99K miles on it so it should have a lot of
life in it.
Thanks, Al sends
Old Aug 20, 2006 | 09:50 AM
Chiovnidca's Avatar
Default RE: 1992 Accord Starting Problems
Have you checked the main relay for cracked solder joints?
Old Aug 20, 2006 | 12:32 PM
sbclemens's Avatar
This site will help you trouble shoot the main relay
http://techauto.te.funpic.org/
Old Aug 20, 2006 | 04:58 PM
masteve69
Thanks to all. It was the main relay. God I wish I would have found this
site earlier. In 20 minutes after I got the relay out I was back in business.
Thanks again.
cumminsman
Feb 13, 2008 12:09 PM
dentallabguy
Sep 12, 2007 02:41 PM
KimberlyC
Apr 16, 2006 11:51 AM
cyurgeles
Jan 21, 2006 10:36 AM
wanderer63
Nov 23, 2005 01:17 AM
