1993 Accord - cooling fan don't turn on
Old May 6, 2010 | 03:26 AM
cachinbon's Avatar
Unhappy 1993 Accord - cooling fan don't turn on
I searched in the forum but could not find an answer. My sister's 1993 Honda Accord broke down this weekend. She said the car overheated. I took a look and noticed all the coolant was gone & was leaking from underneath the car. I managed to find that a "bypass cooling hose" was the source of all the leak. I changed the hose. put in new coolant. started the car. car warmed up but cooling fans would not turn on even when the coolant was hot. I tested both fans & they fine. what can I do next?
Thank you guys in advance!
Old May 6, 2010 | 02:13 PM
deserthonda's Avatar
chk fuses, relays, t-stat opening up ?? could also be a bad sensor for the fans located on the t-stat housing ,,
if t-stat opens on time, unplug the connector and jump the wires together if fans come on you got a bad sensor
http://techauto.awardspace.com/overheating.html
read this, it will help to diagnose
Old May 6, 2010 | 05:14 PM
cachinbon's Avatar
Thank you! I'll test these things
Old May 11, 2010 | 11:42 PM
cachinbon's Avatar
Just wanted to say thank you for the link. I did the troubleshooter and found the car had faulty wiring...saved me a whooole lot of guess work!
Old May 12, 2010 | 06:47 AM
Diagnosing almost always works better than guessing...
Old May 12, 2010 | 06:27 PM
glad that you got if fixed........like i always say,, always diagnose first ..
Buzo209
May 4, 2013 08:37 PM
mishakol129
Apr 7, 2013 06:48 AM
CDJDM07
Aug 24, 2011 09:51 AM
Equalizer
Feb 20, 2007 08:57 PM
nerrissa1969
Feb 4, 2007 01:45 PM
