1993 Accord rotor replacement.. Axle nuts??
Old Jan 9, 2012 | 09:59 PM
  #21
93Accord2.2's Avatar
The axel nut is like 180 ft lbs, was in the pic I posted. for the others see this pic......40 vs 33 call if good.
I kind of doubt we made it to 180 ... Do you know if any loan a tool parts store things loan torque wrenches out? I don't imagine just any one of them going all the way to 180 though ... Well, I don't know, the end of the spline or spindle or whatever it is is poking out through the head of the bolt say maybe 1/8th of an inch? Sound about right?
You guys are helpful as hell - thanks!!
Old Jan 9, 2012 | 11:39 PM
  #22
If you tightened the axle nut down and punched it, it will not move and you should be set.
The 4 bolts in the back of the knuckle holding in the bearing are 33 ft-lb, so you torqued them pretty close to specs.
You should be all set.
Old Jan 10, 2012 | 08:35 PM
  #23
Well for as much as Ang pays us we have to do something....oh wait we don't get paid
Our payment is in your quote above...thank you.
Old Jan 11, 2012 | 02:46 PM
  #24
BB_cuda's Avatar
Is it just me or have you guys heard that you shouldn't reuse the axle nuts? At least for my 89 model you're not supposed to. They are considered one use items. the replacement nuts are ~$3.75 per side from rock auto. I bought them along with lower ball joints and upper control arms.
Old Jan 11, 2012 | 04:27 PM
  #25
Yes, you're supposed to use new ones each time.
But I've re-used them & not had a problem. It sorta depends on how much they're chewed up from being staked into the groove on the axle stub.
But they're not very expensive to get new ones.
Old Jan 11, 2012 | 05:04 PM
  #26
I know how much I appreciate being appreciated and I know it only happens 1 in 10 times you do something for someone
Old Jan 11, 2012 | 05:05 PM
  #27
I meant to ask about re-using them because I had also read that ... I was able to punch them both in on a fresh spot so I think they're fine ... But if you people tell me to go and get the new ones, I will, because I am not the expert here
Old Jan 11, 2012 | 05:56 PM
  #28
Well, generally you should get new ones; the service manual say that. However, for the most part, you can re-use them with no problem. Most mechanics I know re-use them without problems. I never seen a mechanic put on a new one, unless I brought them one.
Old Jan 11, 2012 | 07:03 PM
  #29
Okay and I don't imagine putting anti seize on the two pieces we had the horrible time getting apart is a problem? We also put some on the spindle that goes through the wheel on one side because it was a bitch getting the first one back on
Rdellar
Jan 18, 2015 06:27 AM
gfam
Apr 19, 2012 08:48 AM
Tony1M
Sep 22, 2010 06:54 AM
Tony1M
May 10, 2007 09:55 AM
nixalot
Jan 25, 2007 02:02 PM
