1994 Accord--Finished Head Gasket and now no Power
Old Jul 20, 2013 | 07:25 AM
  #31
Go to ~ 14-169 (if we have the same "downloaded" version) in the manual and shows the inspection and adjustment process.
Old Jul 21, 2013 | 12:50 PM
  #32
faran's Avatar
Almost A Senior Member
Can you please point me to the place from where you have downloaded your version?
I have adjusted the throttle cable, just need to adjust the transmission throttle cable and then finally Ignition timing.
Thanks in advance for your help guys, really appreciate it.
Old Jul 22, 2013 | 08:51 AM
  #33
faran's Avatar
Final Update:
So I have moved the distributor lil bit backward(advanced).
Man, I can tell the difference, car is running so much smooth and response is way better. It's like day and night difference.
So I checked the mpg while distributor was retarded, it's nearly 30mpg now going to check after adjusting the distributor.
Thanks again for all the help and cooperation.
McDesign
May 21, 2014 06:39 PM
Maxximus
Sep 11, 2012 04:44 PM
pancho88
Mar 20, 2012 06:06 PM
fordmechanic
Mar 17, 2011 08:38 PM
thunder_x
Jul 9, 2007 11:57 AM
