finished rebuild on my 96 auto tranny but it wont shift into second
Old Mar 15, 2011 | 11:47 PM
fordmechanic's Avatar
Default finished rebuild on my 96 auto tranny but it wont shift into second
every gear works and works very well since the rebuild but it wont shift into 2nd unless you put it into 2nd. im thinkin shift solenoid but no codes are coming up. 96 accord f22b2 with the px4b tranny. Any ideas?
Old Mar 16, 2011 | 10:22 PM
draker's Avatar
I would check to see if the solenoid clicks when power is applied.
Old Mar 17, 2011 | 01:38 AM
solenoids are working but i think i have an electrical problem, idk if its in the wiring or tcm
Old Mar 17, 2011 | 02:08 AM
I have little experience on the workings of a transmission.
The TCU sends power to the shift solenoid to open it. You could back-probe each wire at the shift solenoid connector. Then connect a test light to each wire, then ground the other end of each test light. You would have two lights connected. If you use enough wire, you can route the lights to the windshield. Then you can watch the lights turn on/off while driving to see if power is getting sent to the solenoid from the TCU?
I just don't know when the TCU sends power to switch gears, or the sequence the TCU uses to go from 1-2, 2-3, 3-4.
Old Mar 17, 2011 | 10:59 AM
i have a manual for the transmission that tells the sequence of the solenoids for each gear change, im going to do some testing so i can figure it out
Old Mar 17, 2011 | 08:38 PM
code p0715 came up last night for the front speed sensor, im guessin thats the problem
live2rice
Aug 8, 2021 04:20 PM
McDesign
May 21, 2014 06:39 PM
faran
Jul 22, 2013 08:51 AM
pancho88
Mar 20, 2012 06:06 PM
naveen_r
Jan 12, 2011 07:13 PM
