1994 honda accord reads high pressure on low side
Old Jun 24, 2012 | 07:36 AM
  #31
johnno0213's Avatar
Default Test results on the pressure switch
OK Back at it. Here are the results.
AC Switch Test with AC on and the thermostat plugged in again -
I get the Beep at presure switch!
DC Volt reading a second time on P/S connector plug and have:
Red/White = 11.59
Blue / Yel = 3.87
Light Test from Battery Ground AC on & Thermo plugged in
Grounded test light at bat and on red/white = Aux fans go on ?
Grounded test light at bat and on yel/black = Nothing
I will look for test trace back directions in manual for trouble shooting as recommended.
Old Jun 24, 2012 | 11:18 AM
  #32
If you did the voltage test correctly, there is a ~8V drop across the pressure switch. There should be negligible drop. Suggest rechecking, as replacing pressure switch will require refrigerant removal.
Another check is to check resistance across pressure switch contacts. If there is a measureable resistance, the switch is bad.
When you grounded the red/wht through the test light you provided ground path and enabled the cooling fans to run.
Possible problem w/ the blk/yel (to thermostat?). It should have read 12V if the keyswitch was On. Either fuse 8 open or wiring fault. Again, check your results.
Old Jul 18, 2012 | 12:59 PM
  #33
johnno0213's Avatar
Default We tested the pressure switch and have a reading
Is the switch good? the reading on the presurre switch was a -4.36 when meter set on ohms.
Old Jul 18, 2012 | 06:59 PM
  #34
Switch resistance should be near zero, < 1 ohm. Note, when you zero an analog meter or check a digital meter w/ shorted terminals, note the resistance. This should be subtracted from digital readings.
eduard
May 9, 2013 12:11 AM
fudads
Aug 22, 2011 07:38 PM
adamswt
Sep 13, 2010 05:19 PM
ssudbury
Aug 1, 2010 08:57 PM
piconrule
Jul 24, 2009 02:38 PM
