1994 Honda Accord Sedan vtec fuel inj.16v
Old Mar 27, 2011 | 10:07 AM
Just one point. The rotor for a vtec is different than a non vtec.
Old Mar 27, 2011 | 10:29 AM
You may have an aftermarket distributor, although all the ones I've seen look to be rebuilt OEM.
The "diamagnetic screw" is probably caused by the nearby powerful magnets in the CYP/CKP/TDC sensors in the distributor.
Yes, igntion switches fail regularly on Accords and other Honda products. Not sure but maybe they're carrying too much current in the switched circuits.
Old Mar 27, 2011 | 06:55 PM
johnno0213's Avatar
Default blk/yel wire to the distributor Car fixed !
Turns out I have 12V all the way down except at the igniter / ICM.
I noticed a crack in the black wire harness the one the fits under the dizzy in a clip & when I opened it up I discovered that the black-yellow wire was broke so I did a soder and put back together and the car runs again.
I must of broke connection all the way when I was replacing the ICM the first time.
Thanks for your help I learned a lot that is for sure!
Old Mar 27, 2011 | 09:54 PM
Excellent. Thanks for telling us how it worked out.
cd51994accord
Jan 30, 2014 12:56 PM
Duhvidd
Aug 30, 2013 03:13 PM
hondaracing14
Jun 28, 2010 07:55 AM
Jmoney
Sep 24, 2008 04:55 PM
newtohondas
Sep 19, 2006 01:55 PM
