1995 Accord stalling issue
Old Feb 17, 2012 | 07:00 AM
Joseph97297's Avatar
Default 1995 Accord stalling issue
Just replaced the water pump, timing belt, balance belt, tensioners, valve gasket, oil pan gasket, and aux belts on my 95 Accord EX. Now sporadically, after starting up, when you drop down into reverse or drive, it will shut off. Cranks right back up with no problems, and away you go. Doesn't cut off any other time, and only has done this 3 times since the repair job.
Never has done this before, and I don't know what I could have affected with the timing/water pump job, so any ideas or advice? Thanks.
Old Feb 17, 2012 | 06:51 PM
Hummm...Three times over what period of time?
Since it has only happened three times, try to notice (if or when it happens again) if it does this only when the car is cold, sat for a long period.
Old Feb 17, 2012 | 08:19 PM
Three times over a week. It only did it when it was hot. I had to run into Lowe's after a 30 minute drive, 5 minutes in, cranked up, dropped into reverse and stalled. Fired right back up, no problems.
Was searching the forums and got to reading the IACV info, would that cause the issue to start suddenly? We finished last Friday with the timing and stuff, and before that no problems.
So I will be taking the IACV and following the cleaning procedure outlined here and maybe that will help.
Old Feb 18, 2012 | 08:41 AM
Might as well clean the tb, both sides of the butterfly and the edge where is seats off......Also read up on adjusting the FITV.
What is the base idle at?
Old Feb 18, 2012 | 05:44 PM
Base is at approx. 700 or +/- a little.
Can't get to it today as other things have cropped up, but will be doing some cleaning tomorrow.
Will be doing some reading tonight and make a list to check off as I get into it.
Thanks
Old Feb 18, 2012 | 09:48 PM
renzki's Avatar
ECT Sensor I guess
Old Feb 22, 2012 | 04:38 PM
Well, cleaned the IACV, and so far, no issues. Hopefully that will have solved the issue. Now gotta move on to the other vehicle taking up floor space.
Thanks for the advice.
Old Feb 22, 2012 | 08:11 PM
Fingers crossed for you....good luck.
r_palmy
Jul 30, 2013 09:35 PM
jcnva
Jul 24, 2013 02:20 PM
iStagl
Dec 4, 2012 05:48 PM
iStagl
Jun 29, 2012 11:41 AM
Slowaccord
Feb 1, 2012 04:58 PM
