1995 EX Won't start, Main relay OK, no power to fuel pump
Old Jun 29, 2015 | 12:03 AM
  #41
tempola's Avatar
Originally Posted by Malcontent
1995 EX 4 cyl Vtec:
I had just replaced the fuel filter, and when I did that I pulled the wire loose from the fuel pump so I could play the radio while I worked. Realized I had the ignition in run position for a while later. Finished that and car drove fine for one day. Next day I go to start it, and the check engine light stays on for about 10 seconds before I hear the fuel pump come on. Then it cranks. Keeps doing that and seems to get longer and longer before the fuel pump comes on. Cranked it maybe 4 or 5 times, then last time I smelled something burning from dash and it won't start. I pulled the main relay, thought it smelled kind of smokey. Replaced still no start.
I tried to pull codes before replacing main relay, got nothing from the Check engine light, tranmision code was 14
I just traced down a identical problem..no spark, no fuel, and CE light would not go off...smokey smell.turned out to be a fried curcuit in the ECM. Sice I am electronic inclined, I was actually able to fix it.
There is a 220UF 35 volt electrolytic cap inside the ECM that shorted out, and burned a curcuit in two. it was righ next to the reverse polarity diode. this curcuit directs 12 Volt into various parts on the board.
I managed tyo replace the cap, and repaired the burned curcuit trace with a piece of buss wire....after that, it started right up.
Old Jun 29, 2015 | 12:46 AM
  #42
If you could post a picture of your fix that would be very helpful.
Thanks for posting.
crazylegs12
Oct 15, 2011 07:48 AM
uraceulose
Oct 2, 2009 11:45 PM
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
fastdart360
Jan 24, 2008 07:52 AM
