1995 starts and dies
Old Apr 26, 2015 | 09:15 AM
Tchitman's Avatar
Default 1995 starts and dies
1995 honda accord starts and dies Need help replaced distributor main relay and ignition switch help please
Old Apr 26, 2015 | 10:32 AM
How long does engine run? seconds, minutes?
Suggest checking fuel pressure. There is a tap on the fuel rail that requires a special fitting to attach fuel pressure gauge.
If pressure is low/disappearing when engine dies, then either fuel pump, fuel pump inlet screen blockage, or fuel filter blockage.
If pressure is good, look for an electrical problem w/ power to the distributor; bad wire, ignition switch, or distributor.
Naka69
Feb 16, 2022 02:55 PM
lilmammaszoo
Jun 21, 2012 08:40 PM
dmatt40
Dec 21, 2009 07:07 AM
zx6r98
Sep 10, 2009 03:34 PM
bumbalough
Mar 30, 2008 03:53 PM
