1995 V6 Accord with issues.
Old Jul 25, 2014 | 10:10 AM
Turbo Tahoe's Avatar
Originally Posted by Turtlehead
Use either Honda fluid or try and find some Red Line.
The VSS should be located on top of the transmission near the firewall close to where the transmission bolts to the engine block.
As far as not running well in the wet weather I would get a spray bottle and while the engine is running fine gently mist around then engine electrical connections and vacuum lines, etc. As you carefully work around the engine with the mist you might find the the engine acts up. If so, let the engine dry out and once it runs fine again start misting, but start lower on the engine and work up until you find where there is either a vacuum leak or electrical issue in the area where the engine originally started to act up.
Ok thats a good idea, ill do that before I order parts. I am assuming the cap, rotor, points, and plugs have never been changed tho so I'll start there. Thanks.
Honda ATF is recommended. Honda DW-1 is the current Honda ATF and is full synthetic.
See the attach image for the location of the VSS on your V6.
I will find some Honda fluid then, thanks again for your help your diagrams have made life much easier!
When the speedo acts up, does the cruise control work? Assuming the cruise works?
Good point, if the cruise worked the problem would most likely be the dash but unfortunately the cruise hasn't worked for years according to her.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
takingbacksunday105
Mar 23, 2005 04:25 PM
