1996 Accord F22 SOHC
Old May 30, 2012 | 10:03 PM
How good is your distributor cap?
Old Jun 1, 2012 | 06:18 PM
and rotor. Then you might think about replacing the plugs.
Does the mis fire happen at idle or at speed....say @ 1500 to 2200 rpm?
Old Jun 5, 2012 | 01:24 PM
aaroadrally's Avatar
it happens once the car warms up then i rev the engine to about 2k and when the rpm drops to idle it starts with the misfire
Old Jun 5, 2012 | 09:25 PM
What poorman212 was asking about the 1800-2200 rpm was to see if the EGR ports are causing the misfire.
It is a common problem and is simple to fix. Just open the common DIY thread on top of the gen tech help forum. There is a link to cleaning EGR ports under the 94-97 accord heading.
Old Jun 13, 2012 | 09:51 AM
still not working, I have cleaned my throttle body and taken it completely apart, I also cleaned the egr valve but I could not find a thread for it. I put new plugs and wires and also got my ignitor checked and it passed. This issue only happens once the car gets into closed loop. I will have the car idling and riv it up to abut 2k hold it there for 6-10 seconds and when it goes back to idle speed the car begins to misfire on cylinder one and sometimes even die out. Please help!
Old Jun 13, 2012 | 06:54 PM
There is a link in the thread below for EGR port cleaning by honda dude. I also linked an ericthecarguy video for this as well.
https://www.hondaaccordforum.com/for...56/#post245852
Old Jun 20, 2012 | 12:02 PM
  #17
you guys are great the car runs amazing now, I did get a code for insufficient egr valve lift, but i deleted it and have not had any codes yet
maverick2k7
Feb 5, 2011 08:59 PM
gsawyers
Apr 12, 2010 10:42 PM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
