1996 accord lx 4 cyl. A/C problem need help troubleshooting
Old Dec 4, 2011 | 12:23 PM
going to assume this is a nippondenso compressor
Attached Thumbnails 1996 accord lx 4 cyl. A/C problem need help troubleshooting-5th-gen-ac-clutch-gap.jpg
Old Dec 4, 2011 | 12:29 PM
osanyin's Avatar
It appears to be a bad compressor....
The bearing already started making noise and the covering on the electromagnet is already melting.....
Old Dec 4, 2011 | 12:35 PM
Ouch, sorry to hear that.....I was hoping for the best.
Old Dec 4, 2011 | 12:40 PM
osanyin's Avatar
It happens.....lol
Thanks for all your help. I'm just going to buy a new one and take it from there...
The system should be vacuumed for at least 30 min, correct?
I was looking at my service book but it doesn't go into the a/c. If you know, how much oil should I pump into it once I replace the compressor?
Old Dec 4, 2011 | 01:00 PM
Look in the "Common DIY Threads" sticky at the top of this section for a manual you can download (sect 22, pg 22). I will only hit the highlights, TX might chime in with additional info....
For the compressor, drain the old one and replace with ~ same amount removed. Also suggest replacing the filter dryer, add ~1/3 oz of oil for that.
Old Dec 4, 2011 | 01:23 PM
osanyin's Avatar
Thanks for all your help...I'll let you know how it goes
jesuss123
Jul 29, 2015 11:49 PM
BSims66173
Apr 14, 2013 06:11 PM
bossBrookie
Aug 27, 2012 06:34 PM
ejcr032
Mar 15, 2011 04:35 PM
rplowden
Jan 22, 2008 03:17 PM
