1997 Accord SE overheating
Old Aug 24, 2010 | 02:42 PM
tbrower's Avatar
Default 1997 Accord SE overheating
I have replaced the thermostat, and this helped for the most part. However, the temp guage still goes way up to the red zone - but only occassionally and only in city traffic. It moderates fine while driving at speed.
I have witnessed the cooling fan running both with the Engine on and with the engine off, so I am assuming the Thermo Switches are OK. Not sure this is a valid assumption.
The car only seems to do this occassionally - on hot days and in city driving.
The car has been to a radiator shop twice: the first timme they couldn't figure it out so they flushed/filled the cooling system and called it good. The problem persists.
Took it back to the radiator shop and they still can't find anything. They claimed the coolant level was low, but they had just flushed/filled it 2 weeks ago.
Any chance I need to replace the thwermoswitches - even though the cooling fan runs as expected? Any other ideas?
Thanks!
Old Aug 24, 2010 | 05:54 PM
Do both fans turn on when you have the car running and turn on the a/c? How much coolant had to be added after 2 weeks?
Here is a good DIY page about troubleshooting the cooling system.
techautorepairs.com/overheating.html
Old Aug 25, 2010 | 11:21 AM
tbrower's Avatar
Yes, both fans run if Engine is running AND AC is on.
Not sure how much coolant the radiator shop added, if any. The coolant level read at the High mark on the reservoir BEFORE taking it to the radiator shop, and afterwards, it looked to be at the same level.
Thanks for the link to the DIY page... I'll check it out.
1997 Accord SE
Old Aug 25, 2010 | 02:44 PM
When the engine is cold, you should remove the radiator cap and see if the fluid is filled to the top of the radiator.
Old Aug 25, 2010 | 07:57 PM
"tbrower"- Might be splitting hairs here "Yes, both fans run if Engine is running AND AC is on". "AND" being my question. With the AC off, both fans do cycle on and off as the car warms up? After checking what PA suggested, please be sure to bleed the cooling system as well.
Jennifer Wheeler
Feb 1, 2012 06:41 PM
JB79
Aug 28, 2011 08:53 AM
brent97accord
Aug 3, 2010 10:54 AM
goldentrail
Dec 23, 2009 01:46 PM
Notpretty
Jul 22, 2007 09:42 AM
