1997 Honda Accord Overheating
Old Aug 28, 2011 | 01:40 AM
JB79's Avatar
Default 1997 Honda Accord Overheating
I have a 97 Honda Accord 4 cylinder that keeps overheating. I have replaced the thermostat, flushed the cooling system, replaced the water pump, replaced the radiator and cap, & one fan that was not turning on. I have replaced the antifreeze (50/50). After I drive it for a while & stop antifreeze is coming out of the overflow onto the ground. There is no antifreeze in the oil & no bubbles forming when I have the cap off looking into the radiator. It does just fine until I hit traffic or stop. I don't know what else to do. Please help.
Old Aug 28, 2011 | 02:40 AM
Wow, you replaced just about everything that you can. I would do a compression test to see if any cylinders are losing pressure. You can try a leak down test as well.
Old Aug 28, 2011 | 08:53 AM
A chemical test for exhaust gases in coolant is indicated. You may have a failed head gasket.
Jennifer Wheeler
Feb 1, 2012 06:41 PM
tbrower
Aug 25, 2010 07:57 PM
brent97accord
Aug 3, 2010 10:54 AM
goldentrail
Dec 23, 2009 01:46 PM
Notpretty
Jul 22, 2007 09:42 AM
