1998 ex 5 speed accord ododmeter doesnt work
Old Sep 8, 2015 | 05:32 PM
jfuentes117's Avatar
Default 1998 ex 5 speed accord ododmeter doesnt work
i went to vatozone(autozone) lmao... and code was that my vss failed so i ordered it and replaced and now it says to run 100 miles but my spedometer or oddometer doesnt work any help... my check engine light is still on and my spedo or odo doesnt work
Old Sep 8, 2015 | 07:28 PM
Does cruise control work? If yes, then VSS is working.
If not, then problem may not have been VSS sensor fault, but rather a wiring, connector, or ECM fault. It will take a Volt-Ohm Meter and some resistance checks to determine if a fault exists in the wiring from the ECM to the VSS. If wiring checks good, the ECM is likely source of fault.
Old Sep 14, 2015 | 04:56 PM
Default hhh
yea my cruise controll has never worked but my spedo and odometer was always working.
Old Sep 17, 2015 | 07:22 PM
Do you know the actual code that was given, if so please post the actual code.
Are you getting the same code, please post it, now?
There is a "self test" of the gauge unit that can be done bit lets answer the first question.
umtkyck
Jun 28, 2015 08:08 AM
areyouben
Feb 26, 2014 10:05 PM
rockhoundrob
Dec 12, 2013 01:35 PM
AceszHigh
Apr 23, 2012 06:05 PM
mehoff636
Oct 11, 2011 05:59 PM
