1998 Honda Accord V6 Engine Light ON Code P1457. Please Help.
Old Jan 17, 2014 | 10:14 PM
Yessy Consuegra's Avatar
Exclamation 1998 Honda Accord V6 Engine Light ON Code P1457. Please Help.
Hi HAF, I have a 1998 Honda Accord V6. I have the check engine light on for code 1457. I was told that my Evap Canister is the problem. I want to buy the whole piece so I searched on eBay and found two different Item which are supposed to be the same piece. Can you guys tell me which one should be? Thank You.
Dorman Vapor Canister Shut Off Valve Fits Acura CL TL Civic Accord Odyssey | eBay
98 02 Honda Accord EX V6 2dr Purge Vapor Canister Filter B30 | eBay
Old Jan 18, 2014 | 12:42 AM
I'm moving you to the forum you are now in..Please post in correct forums.
Old Jan 18, 2014 | 12:09 PM
Those are not identical parts, and they are not labeled the same.
One is the EVAP shut valve. The other looks like a filter for the evap.
I did this repair on a friends car. You may want to label the hoses you disconnect to be sure you get them back in the right place. The hardest part is the screws tend to be very corroded. I got one out and the second one I had to cut out.
Here is a video on the repair describing exactly what happened to me.
Old Jan 18, 2014 | 01:48 PM
@PAHonda thank you, very help full video. Can please send a link of a photo showing what the canister look like? I like to buy the entire piece. When I search for te canister only the EVAP shut valve and The filter for the evap comes up.
Old Jan 18, 2014 | 02:08 PM
Go to ebay. Search Honda Accord charcoal canister fuel evap emissions 98 99 00 01 02 Acura TL CL
That is a used part, but the pictures will help when shopping.
Old Jan 18, 2014 | 02:22 PM
@PAHonda I found two pieces not sure which is. Can you please help me out again and thank you.
A) Emissions Fuel Vapor Charcoal Canister for Honda Accord Acura CL TL | eBay
B) 98 99 00 01 02 Honda Accord V6 Front Evap Emissions Control Canister | eBay
Old Jan 18, 2014 | 07:08 PM
A is the one under your car that is also in that video. B must be in the engine bay.
A P1457 is caused typically by the vent shut valve that attaches to the canister.
Old Jan 18, 2014 | 08:21 PM
@PAHonda thanks a lot.
Yessy Consuegra
Dec 30, 2013 06:55 PM
nnvsabari
Nov 19, 2013 08:29 PM
4mfrance
Apr 28, 2012 08:07 PM
bigant
Dec 2, 2008 04:10 AM
ajluu
Jan 3, 2008 12:51 PM
