Sponsored by:
Sponsored by:
1999 2.3l vtec solenoid gasket leaking
Old 04-19-2013, 06:57 AM
grannie613's Avatar
Default 1999 2.3l vtec solenoid gasket leaking
It started as a slow drip last week...now it's a gusher. Can't drive the car until it's fixed. Thought the rocker cover gasket was the source,took the cover off and used rtv gasket maker and replaced the cover.1999 2.3l vtec solenoid gasket leaking-001-1.jpg Started the engine and oil appeared immediately..1999 2.3l vtec solenoid gasket leaking-002-1.jpg The oil is clearly coming from the vtec solenoid. I've been reading as much as I can find on the subject. I can buy a new gasket with filter from
TAS Auto but I don't know for sure what the part number is. The car is a 1999 Accord LX 2.3l vtec. I would appreciate the help.
Old 04-19-2013, 07:40 AM
Can't tell which one is leaking from the pictures, but there's 3 "gaskets".
Parts drawing shows the whole VTEC spool valve as one assembly, with a gasket where it bolts against the head. 15825-P0A-015
The VTEC oil-pressure switch screws into the side, and has a small O-ring gasket. 91319-PAA-A01
The VTEC solenoid is at the top, with a 3-bolt triangle flange shown in your photos. That one is not shown as a separate part, but maybe your dealer parts department can do something.
Old 04-19-2013, 11:19 PM
grannie613's Avatar
Default Problem solved
Parts cost me $23.78 at the local Honda dealer. 1999 2.3l vtec solenoid gasket leaking-008-1.jpg
Removed the air intake tube, the egr valve and removed the 2 bolts holding the thermostat assembly to intake manifold. Tried to used a swivel adapter on the vtec assembly bolts but they were way too tight and I needed to approach them straight-on. Removing the egr valve and pushing the thermostat assembly out of the way was easy. The wife is happy her car is running again and I am happy too.
Old 04-20-2013, 09:08 AM
jkowtko's Avatar
Almost A Senior Member
It's amazing how hard and flat, and leaky, these rubber gaskets get after about ten years or so.
pepaccordcd5
12-05-2019 08:51 AM
datman
01-22-2018 08:59 AM
Tchocky
10-05-2012 12:36 AM
pouncer11
05-19-2012 09:46 AM
kennilope
09-14-2010 09:54 AM
Quick Reply: 1999 2.3l vtec solenoid gasket leaking
