1999 Accord Air Compressor Pulley Replacement
Old May 5, 2014 | 04:01 PM
HondaSid's Avatar
Roader - Do we have different manuals? Mine is titled "SERVICE MANUAL 1998-2002 ACCORD 2/4 DR". Page 21-51 is titled "Compressor Clutch Overhaul". I attached the page on the previous post. I guess it doesn't matter though since it appears the pressure plate should come off without a special tool. Thanks anyway for your response.
Old May 5, 2014 | 08:34 PM
Roader's Avatar
Weird. I downloaded this FSM six months ago and again a few minutes ago and in both cases the page is 21-21, yet it's obvious you posted a PDF of the same page marked 21-51. I don't see how that can be.
Old May 5, 2014 | 08:43 PM
The 98-02 Accord service manual for the 4 cylinder shows the compressor clutch overhaul at pg. 21-51.
The 98-02 Accord V6 supplemental service manual shows the compressor clutch overhaul at pg. 21-21.
Old May 6, 2014 | 08:38 AM
HondaSid's Avatar
redbull-1, Thanks for clearing things up.
Roader - Can you tell me where I can download the Accord V6 supplemental service manual?
FYI - I found out that there are several a/c compressor clutch removal/installer tools that can be rented from AutoZone. I'll follow up when I get my hands on the correct tool and hopefully get the pressure plate off.
Old May 7, 2014 | 08:52 AM
Roader's Avatar
HondaSid, the only manual I have was downloaded from the link in post #2 on page Hose above lower radiator? (01 LX), created 3/8/13. The manual's title is Service Manual 1998 - 2002 Accord 2/4 Dr. It doesn't cover the V6 engine Accord, just the F-series. Page 21-21 is titled Compressor Clutch Overhaul ('98-00 model), snapshot attached. The manual also has page 21-26 entitled Compressor Clutch Overhaul ('01-02 model).
It's the only online 6th Gen FSM I know of.
File Type: pdf
Old May 7, 2014 | 10:26 AM
Show the PDF's bookmarks and it will show the breakout of both the 4 cylinder service manual and the V6 supplement.
Attached Thumbnails 1999 Accord Air Compressor Pulley Replacement-v6-supplement-screenshot.jpg   1999 Accord Air Compressor Pulley Replacement-4-cylinder-screenshot.jpg
Old May 7, 2014 | 11:00 AM
  #17
Roader's Avatar
Huh. So that PDF has both documents in it. Great info, Redbull!
Old May 9, 2014 | 05:30 PM
  #18
HondaSid's Avatar
Default Removing a stuck Denso 10PA ac compressor clutch pressure plate
I found the solution to remove a seriously stuck on, impossible to remove, ac compressor clutch pressure plate (see below).
1. Using an AC clutch holding tool (Autozone loaner tool OEM# 27000) or impact wrench, remove the 10mm bolt from front of compressor.
2. Using the clutch holding tool, hold the front of the clutch while threading one of the bolts from AC compressor mount with a 12mm socket wrench into front of compressor. This will drive the compressor clutch pressure plate off the splined shaft.
Originally, after I performed step 1 above, I expected the pressure plate to come off easily. Unfortunately, no such luck. I pried on it with screwdrivers, sprayed it with PB Blaster, and even tried a jaw puller to no avail. Once I learned about step 2 above, I had the pressure plate off within 30 seconds.
Old Jul 18, 2014 | 07:40 PM
  #19
gpro's Avatar
Thumbs up Stuck Pressure Plate.
Thanks for the great tip!! I just ran into this issue and was able to get the pressure plate off by screwing in the ac mounting bolt into the center of the pressure plate. For a little clarity, you will need to screw it in slowly until the thread bites similar to a tap and dye. Thanks again
ak474u
May 4, 2015 11:15 PM
Alimaxor
Mar 18, 2013 04:22 PM
markgm
Jan 21, 2010 09:41 PM
accordfan222
Oct 14, 2007 07:19 AM
iamiles
Aug 23, 2007 05:25 PM
