1999 Accord EX stalling while slowing
Old Feb 1, 2018 | 07:57 PM
wems26's Avatar
After a recent fuel pump replacement my 1996 accord stalls out when stopping if the gas tank is below 1/2. Could I have gotten a weak fuel pump?
Old Feb 3, 2018 | 04:02 PM
The Toecutter's Avatar
More than likely the hose that attaches the pump to the sending unit is loose allowing some fuel to bleed off when the tank is low. At least that's where I'd look first.
Old Feb 3, 2018 | 10:41 PM
wems26's Avatar
Default which hose
What about the extra hose that attaches to the tank itself near the fill hose. Is that a vent hose? Or the several hoses above the pump outside the tank? Since I have to remove the tank to check those would it not be smarter to put a more expensive pump in since the tank is off? I had gotten a cheap one at Autozone cause I needed it in a rush.
Old Feb 5, 2018 | 09:13 AM
Another possibility is the fuel inlet filter/screen. If that's not attached properly, the inlet to the pump will suck air from the middle of the tank rather than sucking fuel from the bottom of the tank.
mjl5007
Mar 17, 2022 02:21 AM
sree
Oct 13, 2012 09:42 AM
JTOKA
Jan 9, 2012 07:01 PM
Derek Sithol
Jan 19, 2010 12:37 AM
seemerock
Aug 4, 2009 01:31 AM
