1999 Accord V6 Instrument Cluster Dead
Old Mar 29, 2016 | 09:17 AM
AGGIEPILOT's Avatar
Default 1999 Accord V6 Instrument Cluster Dead
Hi all, I just took possession of my grandmothers 1999 Accord V6 with 86,000 miles on it. Right after we got it the instrument cluster died. All gauges (RPM, Speedo, fuel, temp, ODO, ect) quit working. I have pulled and checked fuses on the drivers side panel, pulled the cluster and took off and re-attached all wires, and checked all ground wires I can find. Oddly all lights work still which seems to be the most common issue with the cluster. Does anyone have any suggestions or specific things to check (specific wire locations) before I pull the trigger and take it to a speedo shop? Any help is appreciated!
Old Apr 2, 2016 | 03:49 PM
Edit - Was looking at the wrong shop manual.
The yellow wire is in the 11th slot of the B electrical connector on the cluster and powers the gauges. I don't have a manual with the connectors, but the B connector has at least 22 possible wires. It is probably the largest connector to the gauge cluster. Honda usually numbers wires through each row, so count 11 spots from the end to find that wire (it could be on the end if your connector has rows of 11). The yellow wire at pin B11 should have 12V with the key turned to the II position.
Cardsallday13
Jan 4, 2016 02:09 PM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
imnoweirdo
Jan 29, 2007 05:49 PM
marbro
May 20, 2006 10:13 PM
