2000 Accord Hazards but no turn signal
Old Oct 27, 2011 | 10:21 PM
midnightblade's Avatar
Default 2000 Accord Hazards but no turn signal
Hey guys, I ran into a problem last night after installing my new aftermarket stereo. I disconnected the negative terminal of my battery as I read you should and got everything working. But in the process I accidentally broke the hazard button, not really a big deal but it doesn't spring back into place anymore so I figured I would leave it disconnect.
Then this morning I realized that my turn signals no longer worked. After I got home from work I plugged my hazard switch back in and still no turn signals. My hazards work just fine just no turn signal. So I've been scouring the internet and I guess it might be the turn signal relay? I'm not sure so I thought I'd ask and see what you guys thought.
If it is the signal relay then will I basically just need to follow this guide to get it fixed? how to change a turn signal (hazards) relay: 03 honda civic dx - Honda-Tech
Thanks in advance!
Old Oct 27, 2011 | 10:41 PM
I went over and looked at it..seeing as tho I'm also a member in that forum also..it looks like a good one to follow thru with..
Anyone else have ideas on that link up...?
Old Oct 27, 2011 | 10:55 PM
It may still be the hazard switch.
Carta
Sep 16, 2013 11:21 AM
Gangsta101
Feb 10, 2013 01:50 AM
Scottl1
Jan 10, 2013 11:46 AM
Galdrath
Feb 11, 2012 02:05 AM
wsbowen03
Apr 30, 2009 02:46 PM
