2000 accord oil pan leak
Old Feb 23, 2010 | 01:40 PM
mtrapuzz's Avatar
Default 2000 accord oil pan leak
car is a 2000 accord 4 cyl auto
looks like oil is leaking from the oil pan. I have some RTV high temp silicon gasket i was going to try to re-seal it with. How hard is it to drop the oil pan. Looks like the exhaust manifold would possibly have to be removed at the head to allow room to pull the pan down. And then there is also the transmission or some sort of bracket that is overlapping some of the oil pan bolts. Let me know if anyone has done this. I'm gonna make sure the leak isn't coming from another location. I suppose I could also try to just tighten the bolts a bit, but I can't get at them all with the trans in the way. Thanks.
Old Feb 23, 2010 | 04:24 PM
If it is like my 95, I had to remove the exhaust pipe, the flywheel cover on the transmission, and the cross-member that has my jacking point on it.
It wasn't that bad of a job. I think there is a writeup in the DIY section by deserthonda about doing the oil pan gasket.
Old Feb 23, 2010 | 04:41 PM
Starting in 1998 the pan doesn't have a gasket. You clean it & seal it with HondaBond (Permatex Ultra Grey).
Old Feb 24, 2010 | 12:15 AM
kris_loehr's Avatar
I would verify it is the pan and not the rear main. Is the leak where the oil pan meets the trans
Old Feb 28, 2010 | 02:44 PM
mtrapuzz's Avatar
It was mostly running down the timing chain cover, so yea that side of the pan. I took the cover off and tightened the few bolts that were pretty loose. I got degreaser and cleaned everything up and i will see how bad it gets in a few days.
robo1985
Oct 17, 2012 09:31 PM
theshakes
Jul 3, 2012 07:09 AM
frost506
Jan 16, 2012 07:21 PM
mamtsberg
Sep 23, 2009 02:49 PM
ricj
Jul 15, 2007 01:07 PM
