2000 Accord - Won't start/No CEL/Fried ecu?
Old Jun 20, 2011 | 12:38 PM
fbp cd5's Avatar
Default 2000 Accord - Won't start/No CEL/Fried ecu?
Hi,
I have a 2000 Honda Accord that won't start. The issue began when the CEL came on and I tried jumpering the data link connector. I initially jumpered the wrong pins (1, 12), but did not turn on the ignition. I reverified the pin numbers and jumpered the correct pins (8. 13) then turned on the ignition and realized there was no check engine light. Now, when I go to turn the ignition, no check engine light is visible at startup. I can't hear the fuel pump prime either and the engine just cranks and does not start. Does this equate to a fried ECU? If so, can a dealership diagnose the ECU if I remove it from the car and bring it in? Any suggestions on debugging or links to circuit diagrams for the data link connector would be appreciated.
Old Jun 20, 2011 | 07:49 PM
According to diagram I have pin 1 is not used and 12 is ground, so jumpering those should not cause a problem.
I was not aware that new OBD2 systems would blink codes. What is source of your information?
likethatyall
Oct 20, 2012 10:22 PM
vtorre61
Oct 2, 2012 09:16 PM
MaskedMan
Jun 27, 2010 09:59 AM
MadNoys
May 11, 2009 03:06 AM
jrdew
Jan 16, 2009 11:15 AM
