2000 honda accord
Old Jun 9, 2014 | 09:42 PM
bigbleblanc's Avatar
Default 2000 honda accord
Where is the purge valve solinoid located on 2000 accord with 4 cylinder?
Old Jun 9, 2014 | 10:31 PM
What code are you getting? Has your car been in a place where salt is used on the roads in the winter?
Old Jun 9, 2014 | 11:11 PM
Like PAhonda asked, what code are you getting?
The EVAP canister purge valve is located between the valve cover and intake manifold plenum (somewhat near the pcv valve area, and throttle cable and cruise control actuator cable bracket).
The EVAP bypass solenoid valve and EVAP canister vent shut valve are located on the evap canister.
Old Jun 13, 2014 | 12:05 AM
Originally Posted by pahonda
what code are you getting? Has your car been in a place where salt is used on the roads in the winter?
no salt and its a 2000 accord vtec 4cyl with automatic ...i need to know if the part# p338 for evap purge valve solenoid is correct and where is it located to replace it???you can call me if you would 337-339-1293 brandon
Old Jun 14, 2014 | 07:58 AM
As stated/asked - What code are you getting?
FISA
Apr 28, 2013 09:30 PM
mike.stribling
Jul 14, 2010 01:08 AM
dinzer
May 11, 2005 07:41 PM
DrumProdigy83
May 3, 2005 12:28 PM
tiffany
Apr 29, 2005 07:17 PM
