2000 honda accord
Like PAhonda asked, what code are you getting?
The EVAP canister purge valve is located between the valve cover and intake manifold plenum (somewhat near the pcv valve area, and throttle cable and cruise control actuator cable bracket).
The EVAP bypass solenoid valve and EVAP canister vent shut valve are located on the evap canister.
no salt and its a 2000 accord vtec 4cyl with automatic ...i need to know if the part# p338 for evap purge valve solenoid is correct and where is it located to replace it???you can call me if you would 337-339-1293 brandon
mike.stribling
Jul 14, 2010 01:08 AM
DrumProdigy83
May 3, 2005 12:28 PM
tiffany
Apr 29, 2005 07:17 PM
