2000 Honda Accord Coupe Ex V-6 Passenger Window Problem
Old Aug 20, 2012 | 01:55 PM
jamm's Avatar
Default 2000 Honda Accord Coupe Ex V-6 Passenger Window Problem
Hello,
I was hoping someone could help me with my window issue. My passenger window will not roll up or down and the regulator and motor were replaced a few months ago. My window was fine but currently stopped working. We have tested the motor that was replaced and it seems to be working fine and have tested the drivers and passenger switch. I am assuming this is an electrical issue. Is anyone out there familiar with this issue?
Old Aug 20, 2012 | 08:35 PM
So if you jump F18 from the pass side multiplex to 12v, nothing happens? If true the manual says you have a bad pass side switch, bad wire to the motor or a bad motor.
Old Aug 21, 2012 | 08:46 AM
jamm's Avatar
We were able power the window up/down running a hot wire form the cigarette lighter to the passenger switch…would that hint to an issue with the pass side multiplex?
Old Aug 21, 2012 | 06:59 PM
I'm not with the pass multiplex yet.
Are you sure the fuse in the pass side underdash fues panel is good and sending power to the pass switch - #8 20amp pass side, by the manual I have? The manual I have lists this as a BLU/BLK wire into the pass switch, are you getting 12v to this wire with the key on?
Old Aug 22, 2012 | 04:41 PM
jamm's Avatar
Two seperate technicians did confirm the pass side switch is getting 12v. I'm not sure if this matters or not, but there's a clicking sound in the pass switch whenever attempting to operate the pass window from the driver's side swith.
Old Aug 22, 2012 | 05:15 PM
Talking Hi Member
Did these 2 techs say what the heck was wrong after they looked at it.?
Sounds like they didn't know and that they were guessing..
Attached Thumbnails 2000 Honda Accord Coupe Ex V-6 Passenger Window Problem-funny_road_signs_10.jpg
Old Aug 22, 2012 | 08:30 PM
Are you willing to do some of your own tests? I thought I posted these last night...I am old and slow so who knows what I did.
Attached Thumbnails 2000 Honda Accord Coupe Ex V-6 Passenger Window Problem-6th-gen-pass-multi-window-tests-pt1.jpg   2000 Honda Accord Coupe Ex V-6 Passenger Window Problem-6th-gen-pass-multiplex-connectors.jpg
bryyce62
Aug 18, 2017 07:30 AM
bustum
Oct 11, 2012 11:35 AM
Fat Ryan
Mar 18, 2012 04:39 PM
Legend
Jul 9, 2011 07:19 PM
erikahad
Feb 4, 2010 08:01 PM
