2000 V6: Front Engine Mount?
Old Oct 24, 2013 | 09:16 PM
Florida_Frank's Avatar
Default 2000 V6: Front Engine Mount?
The dealer says my front and right-side engine mounts are "broken." Rather than pay the $600 or so they want, I think I can do the job myself.
With regard to the front mount... it looks like a "genuine Honda" mount is well over $100 while an Anchor mount from RockAuto is around $43. The Anchor mount says, "Does Not Include Vacuum Line Fitting or Nut." Does that mean it is a solid mount that does not connect to the vacuum engine mount control system? If it does not, is it going to make a big difference?
Old Oct 25, 2013 | 07:27 AM
It likely means the mount is solid rubber and may be much stiffer than OEM. Effect will be lots more engine vibration at idle, but I don't know if it would be tolerable or not.
You may want to look at used parts; ebay primarily for this part.
This is not a trivial job on V6 engine. Rear mount may require lowering subframe to access. Forward mount is accessible, but difficult. See following excellent video. Remember, this is the easy one.
I would be sure the rear mount needs replacement by close inspection (if visible) while shifting to D & R and observing motion and looking for physical damage.
Old Oct 25, 2013 | 04:47 PM
Thanks for responding! Fortunately, the rear mount does not need replacing, just the front and right-side mounts. From what you said, I think I'll get the "genuine Honda" front mount and the generic Anchor side mount...
timster4
Jan 6, 2012 07:34 PM
baer77
Feb 27, 2009 03:47 PM
gilwood
Sep 18, 2007 09:19 AM
marbro
May 6, 2006 03:40 AM
