2001 accord. will not crank help!!
Old Apr 11, 2014 | 04:13 AM
Melissa Mcdowell's Avatar
I was told this about the timing was he tired to fix it, but still is not starting.
Old Apr 12, 2014 | 05:06 PM
ok, today took disturber cap off found oil all over the computer, cleaned it off. it now starts but its really rough.. step dad said its "skipping" put it into gear and it dies. any clues?
Old Apr 12, 2014 | 05:13 PM
Sounds like you meant that oil was all over the inside of the distributor. Even though you cleaned most of the oil off, there is a chance some residual oil or oil leaking in from the seals may be causing some or all of your issue with the car starting and stalling.
Old Apr 13, 2014 | 04:59 AM
holmesnmanny's Avatar
If the green light is blinking that means the immobilizer is having issues.
Old Apr 13, 2014 | 07:15 AM
what seals would I need to replace ?
Old Apr 13, 2014 | 01:41 PM
There is an internal seal and an external o-ring.
https://www.hondaaccordforum.com/for...ributor-53904/
Before any distributor seal/o-ring replacement, you may want to do some more tests to try to narrow down if the issue is related to a distributor component or something else. See this link:
Part 1 -How to Troubleshoot a No Start (Honda 2.2L, 2.3L)
Old Apr 13, 2014 | 06:08 PM
  #17
Unless you are leaking large amounts of oil into distributor, this is unlikely the reason for no-start or weak spark. I had oil draining through a distributor on my 94EX for a long time w/o problems.
Earlier you said you were seeing a spark. If this is still the case, then weak coil is more likely the source of no-start.
Old Apr 17, 2014 | 08:50 PM
  #18
well found out what the problem was. a wire was hooked up wrong. car is throwing out code po505 now.
Old Apr 20, 2014 | 08:45 AM
  #19
update... took the idle air control valve off and cleaned it. running wonderfully now. thank yall for all the help
Milanodan
May 17, 2014 06:39 PM
Robert Pemrich
May 15, 2014 05:23 AM
Thrawbrob
May 6, 2013 06:04 AM
fading
Oct 15, 2012 09:20 PM
niknik57
Apr 16, 2012 10:47 PM
