2001 LX AT - Brake Lights Not Working
Old Jun 4, 2012 | 09:46 PM
smh410's Avatar
Originally Posted by PAhonda
If you manually press/release the switch, do the brake lights turn on and off?
No =/
Old Jun 4, 2012 | 10:00 PM
Use a volt meter and check that the wht/yel wire going to the brake switch has 12V to ground (any bare metal bolt will work) when the key is in the II position.
Old Jun 10, 2012 | 11:17 AM
smh410's Avatar
Just as a quick update, The rear brake light in the center is now working. I don't know how, but it is. I just removed the power and plugged it back in, and it started working.
I have tested by power from the brake light switch, and it is working/(power running through)
Now here is the odd part. on the clip that connects to the bulb on the brake light there are two wires the black (ground), and the a Green /w Blue (driver side) Green /w Yellow (passenger side). When testing those for power, there is none when the brake pedal is pressed. All other lights work though. So it seems only these are not.
I traced the wires to a junction of sorts. Based on my observations, the wire comes from the switch. It splits once to the center brake light, and then into a splitter of sorts. That splitter sends power to all the other bulbs on the rear portion of the car. I tested for power after that split, and no power on the live wires.
Am I just not grounding properly? Any other ideas that can be thrown out to help diagnose.
Old Jun 11, 2012 | 05:36 PM
Not sure if you are talking about the brake failure sensor or not.....does this help? Notice the "high mount" does not go thru this sensor.
Attached Thumbnails 2001 LX AT - Brake Lights Not Working-6th-gen-brake-light-cir.jpg
Old Jun 14, 2012 | 12:57 PM
smh410's Avatar
No it is not the failure sensor. It's literally a splitter that splits power coming from the front of the vehicle, and distributing power to all of the rear lights.
The high mount brake light also stopped working again. If it is a faulty senor how can that be proven?
I read a post about someone who just disconnected that piece, and plugged it back in, and the lights started working. I guess I will try that once I get home.
https://www.hondaaccordforum.com/for...e-47505/page2/
Also someone who disconnected something under the light and sprayed it with WD40.
https://www.hondaaccordforum.com/for...g-12649/page3/
Any idea if that was done, why it would cause the lights to come on again.
Lastly, I just realized that the blub that illuminates when the brake is pressed is the same as the one for the left turn signal, and that works...
csh217
Apr 30, 2013 09:03 PM
Will2829
Sep 14, 2012 03:25 PM
Slider65
Mar 31, 2009 03:07 PM
drewk2
May 30, 2008 10:21 PM
arunsam3000
Mar 6, 2007 01:40 PM
