2001 Valve Cover Bolts
Old Jan 3, 2011 | 06:49 AM
hman's Avatar
Default 2001 Valve Cover Bolts
I'm replacing the head gasket on my 2001 Honda accord 2.3L F23a1 VTEC.I have purchased a head gasket set which includes the seals for the valve cover bolts. My question is how do put the new seals on the old bolts? The bolts have a flange on them that the seals have to go over and the rubber that the seals are formed from is very stiff. Do I just put some oil on the seal and drive the bolt on to the seal? I dont want to tear anything up.
Old Jan 3, 2011 | 07:30 AM
Your proposal is what i did to install bolts through seals. What other option is there?
Old Jan 3, 2011 | 05:09 PM
Oil and warm them up with a hairdryer to make em softer.
Old Jan 3, 2011 | 05:24 PM
hman's Avatar
Thanks for the quick replies guys. I,ll follow your advice and heat them up and put some oil on them.
Old Jan 3, 2011 | 06:31 PM
Good idea to warm. I lubed them, but drove them through cold,..if you call Houston summer cold!
Old May 23, 2015 | 06:41 AM
BlueBoy's Avatar
Another option is to add a cone over the treads to help stretch the gasket over the flange.
I used the tip from a caulk tube cap. I cut it off at the diameter of the flange and just twisted it onto the end of the bolt. Add a little silicone grease (maybe oil) and it slides on much easier with no hint of damaging the gasket.
Old Nov 23, 2015 | 11:22 PM
Surfer Dan's Avatar
I just posted this YouTube video in another thread about the Valve Cover Grommets. I just used a pair of vice grips to hold the bolt and a small pick-like tool in a circular motion around the bolt. It worked great. Here's the video:
blahblahfoo
Feb 19, 2012 12:00 AM
IDRAGrockerPANEL
May 12, 2010 12:57 PM
03Sleeper
Jun 11, 2008 08:54 PM
live2rice
Feb 5, 2008 06:22 PM
Planefreak
Jan 5, 2008 06:03 PM
