2002 Honda accord cruise control not work
Old Jul 27, 2012 | 11:18 PM
TDRJ's Avatar
Default 2002 Honda accord cruise control not work
The green light not comes on when I depress the cruise control on/off button.
Cruise control not work.
Can anyone help? Please please please give me some suggestions. I am a broke college student and cannot afford a shop. Thank you for your time and consideration. Any advice would be greatly appreciated!
Old Jul 28, 2012 | 01:17 AM
my1st.honda93's Avatar
check your fuses?you have two boxes 1 under the hood 2nd driver side bottom left foot kick panel
Old Jul 28, 2012 | 09:47 AM
Check the fuses as suggested. Looks like 6 and 9 are in play here.
Do you have a volt meter to test the switch?
Attached Thumbnails 2002 Honda accord cruise control not work-6th-gen-cruise-switch-wire-diagram.jpg
Old Jul 31, 2012 | 02:39 PM
TDRJ's Avatar
Thank you guys. Today I try to Cruise control, it's work. But I didn't do any thing.
Old Jul 31, 2012 | 02:44 PM
Dr. Drivability's Avatar
Talking
broke college students need cruise control why?
Old Jul 12, 2015 | 02:59 PM
marty_gilbert2001's Avatar
Default Check brake switch first
I have an 2002 Accord SE. I cannot stress this enough. After you check your fuses and they are good, then then the next thing to look at on accords is the brake pedal switch. Even if your brake lights work, start here. I spent 3 days digging through possible causes. I check every sensor, twice, they were all good. I checked the 14p cable and everything tested good. I tested the airbag clock spring or reel, whatever you want to call it. I tested both the switches and they were good, everyone posting about the main switch not lighting up should know more than likely the bulbs are blown in the switch. I spent most of my time trying to get the main switch to work under the idea that it was working when it lit up. Not knowing the two bulbs inside were bad. The airbag was replaced under recall and the day Honda replaced it is the day the cruise stopped working. When I took the panel off to test the wires i saw they were taped with electrical tape. So i thought Honda had broke it. They tested the airbag reel and said it was not them. So, once again i was at a loss. I never thought to really check the brake switch. My brake lights worked fine and I had made sure it was making good contact with the pedal. Out of other options I went back to the switch and looked at it very closely. I noticed it was only pushed in about 99.9% of the way. That .01% will not effect the brake lights or come up when testing the 14p cable on the cruise module. So, after testing every switch, sensor, cable, fuse, relay, and everything else, all it took was a 16th of a turn on the brake pedal switch.
ArcticHonda
Nov 24, 2023 05:03 PM
A ROD
Mar 3, 2011 07:16 AM
fxdwg73
Nov 12, 2010 08:03 PM
MisterBen
Dec 22, 2008 05:01 PM
aml22001
Mar 28, 2008 07:29 PM
