2003 Accord LX I4
Old Sep 12, 2014 | 02:46 PM
YeuEmMaiMai's Avatar
^ unfortunately I really do not have the tools to properly test but the data scanner shows voltage below normal for that sensor. Car was involved in previous accident and he indicated that it appeared previous owner was lax on oil changes
sensor reading WOT was < 3.5V should be at least 4.5 from what I know
Old Sep 13, 2014 | 08:22 AM
Well without testing it is a bit of a guess.
If you/he wants to replace the tps be sure to get it set correct, again Honda does not sell the tps alone. You have to get the entire TB from Honda. Are there any "bone yards" there....you might try getting a used TB. If not, get an aftermarket tps and go from there.
Old Sep 13, 2014 | 09:25 AM
TPS fault can be TPS, connector, wire, or PCM. It pays to check for each possibility before replacing.
I did find that TPS is avialable as aftermarket part on RockAuto and likely elsewhere.
Same caution applies to Vtec pressure switch; switch, connector, wires or PCM could be causing electrical fault.
Old Sep 13, 2014 | 03:48 PM
he sent me a pix of the engine pay and nothing LOOKS out of the ordinary I will follow up with him on Monday to make sure all is well
Old Sep 17, 2014 | 10:44 AM
here is the update
TPS replaced and drivability was much better. Cleaned out both screens for VTEC and no more error code for the solenoid and drivability returned to typical Honda standards.
Old Sep 27, 2014 | 07:09 AM
final update to thread, he removed the TPS sensor and cleaned it up, it was loaded with carbon from something. dipped it in pure isopropyl alcohol and reinstalled it after letting it dry. that code is gone. At first it sounded like he replaced it, sorry for the confusion.
next we did an engine flush treatment and then removed and cleaned both screens and , voilą, the V-TEC solenoids are now working as they should.
car is back to perfect drivability wise.
nightowlll2010
Jun 1, 2013 12:55 PM
hoonhooon
Jan 7, 2008 06:47 PM
Jeff247
Mar 28, 2007 04:22 PM
gdr_11
Apr 7, 2005 08:58 PM
