2003 ex sedan 3.0l noise from top
Old Oct 11, 2019 | 07:41 PM
snntuson's Avatar
Default 2003 ex sedan 3.0l noise from top
Wondering if anyone out there has experienced what I am?have a 2003 accord ex sedan v6 3.ol.140k miles recently getting some noise on top motor by power steering pump. Disconnected pump still have noise.Thinking valves maybe need adjustment,and or belt tensioner maybe going out believe I saw a post on that possibility as well.also about a tsb where something loosens up and needs to be retightened.code popped up a cpl days ago for crank sensor,the hits dont stop coming it seems, wondering if I should attempt doing the valves 1st and check timing belt tensioner before I buy a crank sensor,noise was there before crank sensor code.any of u have an idea or route I should take feel free I appreciate any info or advice.dealer wants 780 to adjust valves.will post video of noise as soon as I can find it $#/!!
Old Oct 12, 2019 | 09:29 PM
EXV6NIGHTHAWK's Avatar
Has the timing belt and tensioner been changed before? Could be timing belt tensioner rattle. My 03 would rattle at cold start up and go silent after a few minutes.
Old Oct 13, 2019 | 07:07 PM
snntuson's Avatar
Believe the prior owner had it done at 90k according to label in engine compartment,noise is continuous even after start, definately going to look into it.was hearing tensioner can cause noise.hoping nothing internal,thanks for response
wolverine222
Apr 26, 2016 06:18 PM
techpro87
Oct 26, 2014 11:36 AM
jose1036
Jul 9, 2014 12:23 AM
umg1989
Jan 24, 2013 09:44 AM
akennedy89
Mar 5, 2010 06:55 PM
