2003 honda accord keyless door lock not working
Old 04-22-2022, 12:27 PM
sido's Avatar
Default 2003 honda accord keyless door lock not working
Hello Everyone,
The keyless entry system does not work anymore in locking/unlocking the doors in my 2003 Honda accord EX.
First I though it was the battery that has died, so I replaced the battery with a new CR1616 lithium battery. Still the keyless entry does not work.
However, I can Lock/Unlock the doors manually and the power Locks work very well
Please I need help to make the keyless door lock/unlock.
Old 04-22-2022, 05:14 PM
Do you have a second remote to try keyless entry to eliminate an issue with your remote?
Old 04-25-2022, 04:12 AM
sido's Avatar
I tried with the spare key with remote that I have and it didn.t work.
I also tried reprogramming the remotes again and both didn't work.
Old 04-25-2022, 08:11 AM
I have 97 accord and I've been having the same issue as you.
I believe it has something to do internally with the receiving module from the keyless fob
I'm 99% sure that said module is either under the steering wheel or under the driver seat.
Old 04-26-2022, 04:59 AM
sido's Avatar
The Transceiver is in the Driver's door panel. It is in Power Door Control units. But can this unit go bad?
I have also suspected that module but I have not b=seen it been changed.
Does anyone know if this unit could be responsible?
Old 04-26-2022, 05:02 AM
I honestly have no idea, I’m a bit fed up using my key so I’ll probably be ripping my door apart soon
mikejones305
10-02-2015 04:26 AM
HateThisHonda
09-19-2013 09:45 AM
Marmarita
07-24-2013 08:50 AM
tycobb280
04-15-2010 08:42 PM
PootsworthIII
12-30-2007 01:12 AM
Quick Reply: 2003 honda accord keyless door lock not working
