2003 Honda Civic LX(A/T) Died While Driving
Old Jun 1, 2014 | 11:31 AM
  #61
There is Jim with a fine point, I'm assuming the cam is off the head......
Old Jun 1, 2014 | 11:44 AM
  #62
Jim, its been a number of years since I took a honda head off. But do you have to remove the cam shafts to get to the head bolts?
Old Jun 1, 2014 | 02:15 PM
  #63
faran's Avatar
Almost A Senior Member
Thanks so much guys. We removed the head, by putting Cylinder #1 at TDC, now piston at no.1/4 is at climax and 2 and 4 are at the bottom.
We are going to try as PM have suggested, should we expect any other damage except valves or hopefully that be it?
Old Jun 1, 2014 | 02:17 PM
  #64
faran's Avatar
Yes, cam is completely off the head. Cam bolts and cylinder head bolts are also removed.
Old Jun 2, 2014 | 06:43 AM
  #65
OK I was ASSUMING that the camshaft was installed into the head. If that were the case, I don't think there's any single position where ALL valves are closed at the same time.
You don't have to remove the camshaft to get the head bolts on an F23; I did that with a 1998 F23A1. Not sure about Civic (D-series) but that's acedemic because faran says the cam was not installed at the time.
Old Jun 2, 2014 | 07:39 AM
  #66
faran's Avatar
Yes, cam was completely off and not installed when we took the pictures. But before we removed cam, brought Cylinder #1 to TDC.
Honestly, that's how we did on F22B1, completely removed cam so tried to follow the same procedure
Old Jun 4, 2014 | 06:39 PM
  #67
faran's Avatar
Ok, a little slow today.
Another idea for you.
Put the spark plugs in. Flip the head upside down and get it as level as you can. Pour water, slowly into the chamber.
Honestly, not sure how guys know every single thing
So took it to machine shop today, he said they all seem fine, but test it by filling Intake and exhaust side with water separately.
Almost, 11 of them are leaking water and we are planning to replace all of em, just to be on the safe side.
Do you guys have any other better suggestions or idea to cut cost while fixing the problem too?
Old Jun 4, 2014 | 06:44 PM
  #68
You might be at the point of seeing what a "reman head" costs vs. them replacing that many valves/guides/seals.
Old Jun 4, 2014 | 07:23 PM
  #69
faran's Avatar
Thanks so much, that's another route. What if we buy valve compressing tool, is it DIY thing or no?
Old Jun 5, 2014 | 04:31 PM
  #70
faran's Avatar
Guys anyone has any input about replacing these valves on our own, is it a DIY?
