2004 accord 4 cyl p0785 code help?
Old Jul 15, 2009 | 08:22 PM
craymond5
Default 2004 accord 4 cyl p0785 code help?
Hi my girlfriend has a 2004 Accord with the 4 cylinder and it has just thrown the P0785 code for the 3-2 shift solenoid. Any suggestions on what the common way to fix this is? I am not familiar with hondas or automatic transmissions for that matter. Is there a shift solenoid part that I just need to replace? The car will all of a sudden flash lights on the dash such as the abs, brake lights and radio lights and start to stall. Sometimes it will stall out completely. Any help greatly appreciated.
Old Jul 15, 2009 | 11:36 PM
finch13's Avatar
I believe there are 2 solenoids on the transmission case towards the front of the car. You can try cleaning their screens and flush them out with Honda ATF-Z1 and reset the codes to see if it fixes it.
Old Jul 16, 2009 | 06:51 AM
I have a 2003-2007 Service Manual for Accord and there is no P0785 mentioned. Closest I found was P0985. Did you see this code or someone told you? Suggest having code checked again and eyeball it yourself.
Analyzethis
Sep 6, 2013 03:47 PM
britcardoc
Feb 15, 2012 06:22 PM
quassu77
Oct 21, 2011 02:04 AM
goodonmotors
Jan 1, 2008 07:04 AM
mrmatrix
Aug 12, 2006 05:39 PM
