2004 Accord 4cyl cooling problems
Old Aug 4, 2013 | 09:03 AM
turbotate1's Avatar
Default 2004 Accord 4cyl cooling problems
I have a 2004 Accord exl 4 cyl auto. Car is running extremely hot, top rad hose is hot, and lower hose is cool to the touch. At first the rad fans were not operational, switched relays and fans now working. Is this a thermostat problem, or possibly a water pump issue?
Old Aug 4, 2013 | 09:15 AM
I moved your thread to the General Tech Help section. The DIY section is not for help questions.
If you switched the relay and it worked, then the original relay there may have been bad.
Can be a thermostat problem, if car is running hot and lower hose is still cool.
Old Aug 5, 2013 | 07:51 AM
cwfmmr's Avatar
If your thermostat isn't opening properly that very well could be cause for over heating and top hose to be hot/lower cool as redbull stated
ynnadret
Oct 2, 2013 12:43 PM
kenwood guy
Sep 15, 2013 03:02 PM
Factoryskate
Sep 8, 2010 06:01 PM
namxas
Jun 13, 2007 12:51 PM
KimberlyC
Apr 16, 2006 11:51 AM
