1994 Hinda Accord EX Cooling Fan Problems
Old Sep 29, 2013 | 01:08 PM
ynnadret's Avatar
Default 1994 Hinda Accord EX Cooling Fan Problems
Neither condenser fan, main cooling fan, or ac is working on my 1994 honda accord ex. Would someone please advise what to try. Thanks
Old Sep 29, 2013 | 04:42 PM
First check Fuse No. 8 (7.5A) located in the under-dash fuse box.
Old Sep 30, 2013 | 07:03 PM
Was or has the ac worked before?
Old Oct 2, 2013 | 11:15 AM
ynnadret's Avatar
Default 94 Accord Cooling fan
The ac and condenser fan quit approx. the same time.
Old Oct 2, 2013 | 11:19 AM
ynnadret's Avatar
The fuse checked ok
Old Oct 2, 2013 | 11:52 AM
jrock24's Avatar
Is there a relay for the fans?
Old Oct 2, 2013 | 12:28 PM
Suggest removing thermoswitch A (on thermostat housing below/behind distributor) and jumpering the harness connector sockets w/ a wire short. Turn keyswtich to ON. Cooling fans should engage and run if they are good.
If they don't and fuses are good (fuses 21 & 34 in underhood fuse box), then either both fan motors are bad, both fan relays are bad, or wiring fault disabling both.
The above won't help AC system problem which is likely a separate issue. Find out if problem w/ cooling fans and then address AC. Leak allowing loss of refrigerant will disable compressor to protect system from operating w/o refrigerant/lubricant.
Old Oct 2, 2013 | 12:43 PM
yankmecrank's Avatar
I just went through this earlier this summer with my 94 Accord. It's got high miles so the fans were probably ready to go. BOTH fans had stopped working maybe not at the same time but when I started using the ac, the car would overheat. When using the ac, the engine would start "hunting" at a traffic stop at idle. It would eventually cut the engine off unless the ac was shut off. Once both fan motors were replaced, the idling problem with ac operating was gone. Recommend disconnecting fans and testing. Hope this helps.
CDJDM07
Aug 24, 2011 09:51 AM
dianepool
Apr 14, 2008 01:16 AM
namxas
Jun 13, 2007 12:51 PM
Equalizer
Feb 20, 2007 08:57 PM
mega502
Apr 29, 2005 03:43 PM
