2004 accord sputtering
Old Aug 16, 2016 | 06:59 PM
Jpat1957's Avatar
Default 2004 accord sputtering
I recently started getting a sputter mostly at low speed. It comes and goes. I just replaced spark plugs with no luck.
Old Aug 16, 2016 | 09:42 PM
Frank_Jr's Avatar
It sounds like a EGR problem. Have you ever done a EGR cleaning on your vehicle? Check also for spark plugs wires arc'ing
Old Aug 16, 2016 | 09:51 PM
Jpat1957's Avatar
Never did an erg cleaning. Car has 180000 on it, is it hard to do a cleaning? Also has coils for each plug? Could it be a bad coil
Old Aug 16, 2016 | 10:10 PM
Jpat1957's Avatar
Also check engine light is not on. Shouldn't it come on with a code if it were egr related
Old Aug 17, 2016 | 02:30 PM
You may want to get the codes checked anyway. Most parts stores do this as a free service.
As for the sputter, does it happen when accelerating, decelerating, or coasting? Any work done on the car not long before the problem started happening?
Old Aug 17, 2016 | 02:44 PM
Jpat1957's Avatar
I put in new plugs , because I had been getting skip. Happens mostly when I am just about moving along 35 mpg. But not all the time. I looked at engine and looks pretty easy to get to erg ports. Will try cleaning on weekend. I wonder if one of the coils is bad. Each plug has its own
Old Aug 17, 2016 | 03:47 PM
Definitely check for codes. You may have a temporary code, where you have some misfires, but not enough to trigger a check engine light. It is worth a shot.
Old Aug 17, 2016 | 09:18 PM
Jpat1957's Avatar
Checked and are no codes
Old Aug 18, 2016 | 05:23 AM
Turtlehead's Avatar
If it is an automatic... Start car, press and hold the brake, put in drive and then slowly press the gas pedal thus slowly raising the rpm's and try and find a sweet spot between idle speed and 3,000 rpm where the engine stumbles. If you find it hold the rpm's at that speed for a while and see if you can force an engine code.
anandram
Jul 5, 2010 11:05 PM
susumu_kumo
Jun 10, 2008 10:40 PM
rsanchez
Nov 8, 2007 02:51 PM
B1ackKn1ght1979
Oct 1, 2007 12:17 PM
jml1124
Jun 21, 2007 09:41 PM
