2004 Honda Accord coupe 4 cyl
Old Oct 5, 2019 | 03:07 AM
Henk Neef's Avatar
Default 2004 Honda Accord coupe 4 cyl
Hello forum, I have a 2004 Honda Accord Coupe 4 cyl. All my brake lights are out. Bulbs seem to be ok. Any suggestions? Please help.... thanks
Old Oct 5, 2019 | 05:29 PM
Moved your post to a new thread.
Can you start the car and get the transmission out of park?
I'd start at the brake light switch on the brake pedal. The video below shows the location.
The switch part pushes against a plastic stopper to open/close the switch. That plastic piece can break, then the switch will never close. Try using a small screwdriver to manually push in the plunger to see if your brake lights work. Do the brake lights turn on?
Unplug the connector to the brake pedal switch. Use a piece of wire to jump the red to the wht/blk wire. Do your brake lights turn on?
Old Oct 5, 2019 | 10:46 PM
Henk Neef's Avatar
I started googling and it was quickly going down the rabbit hole... lol. Anyways, horn worked and can get into gear. So, I went to check the bulbs and ALL of them were bad. Replaced them all and problem solved. Kinda weird how all of them were out simultaneously. I hope it doesn’t end up being more serious later on. I guess I’ll cross that bridge when I get there. Thanks @PAhonda for the help. Might have to go that route one day.
Old Oct 6, 2019 | 01:10 PM
Seanjordan20's Avatar
Wow. I would think the bulbs would be the first part of troubleshooting. Great you got your issue resolved
nedrgr21
Oct 30, 2018 03:31 PM
Analyzethis
Sep 6, 2013 03:47 PM
quassu77
Oct 21, 2011 02:04 AM
craymond5
Jul 16, 2009 06:51 AM
mrmatrix
Aug 12, 2006 05:39 PM
